ECU PROBLEM ???
Old Nov 6, 2006 | 06:57 AM
abra0101's Avatar
Default ECU PROBLEM ???
Hi, I've got a 92 civic ex that wont start and the thing that I check first is the SPARK and found out that it dont have nothing so I tried to test the distributor ( followed the haynes book) and everything in it are ok, I even tried to look at the timing and everything are in position and the last thing I checked is the ECU, now my question is HOW WILL I KNOW IF THE ECU IS BAD ? I JUMP THE TEST PLUG AND TURN ON THE SWITCH BUT IT IT ONLY SHOWS LIGHT (ECU) FOR A SECOND AND THEN TURNS OFF AND SAME ON THE CHECK ENGINE LIGTH WHEN SWITCH IS TURN ON ENGINE LIGHT COME ON AND TURNS OFF NEVER LIGHT AGAIN. IS THE ECU BAD???? I appreciate to any help I may get. THANKS
Civic maniac
Nov 30, 2008 01:58 AM
Captain_Sl0w
Aug 19, 2008 06:41 PM
theShamgod
Aug 15, 2008 02:48 PM
xiong.s2460.mccd
Jul 19, 2008 08:08 PM
civics101
Apr 14, 2007 10:04 PM
