electrical problem
well i think i might have a electrical problem i went in and started my car everything is fine and i went to a friends house and then when i went to start it when i was leaving it wouldnt start and there was no clickin noise from the starter so i jumped it it started but seemed to be idiling low i killed it to see if it would start and nothing jumped it again then started to drive home it was idiling low at the lights then i went to turn a corner n who knows wat happened but some lights on the guage blinked the wipers turned on jurked the car n then it was normal again except for the srs light. other rndom lights turn on n off n blink. alos my damn drivers window wont go up can ne one help me out with this or give me an idea of what it might be??? i checked the fuses and the ignition coil was blown i replaced it but got nothing out of it....
thanks in advance |
RE: electrical problem
I would look for chafed wire, shorted wire, burnt wire or things like that behind steering wheel and gauges. Maybe loose screw floating around and making weird contacts?
