Emissions Test
Old Mar 27, 2014 | 03:43 PM
Kamil Kwarciak's Avatar
Default Emissions Test
Hello ive got a 1992 honda civic vx, it hasnt passed etest in 5 years now it has a 1.5 d15z1 motor 400,000 km , on the test is fails with high HC ( high Hydrocarbon ) anyone have any idea on how to lower it ???
thanks
Old Mar 28, 2014 | 01:50 AM
itburnswhenIP's Avatar
Old Mar 28, 2014 | 01:03 PM
Is the Z1 the original VX engine type? The VX was a special setup and you can't mix parts from other models (e.g. the engine and ECU must match. It also used a special wideband oxygen sensor).
Overcooling the engine (thermostat stuck open or wrong thermostat) will cause the ECU to never enter closed loop mode, which means high emissions.
If you have a proper setup, no misfiring, and also elevated (higher than normal though not necessarily failing) CO and NOx, its likely that the catalytic converter is worn out and needs replacing.
bdouglas
Feb 29, 2008 09:12 PM
tippr
Jul 26, 2007 07:29 PM
Stimpy
Apr 25, 2007 07:09 AM
hondaholic9
Sep 30, 2006 02:48 AM
cdn86gt
Jun 29, 2005 10:49 AM
