Engine - Error Code 13
Old Apr 24, 2008 | 12:11 PM
Madness's Avatar
Default Engine - Error Code 13
Hey guys,
Been racking my brains over my car. It just conks out if I'm driving, and then after it won't start and sometimes it will start.
Anyway I ran the 2 jumpers together to see if i get any error codes. I got error code 13: "BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor".
Is this the reason my car is turning off?
Thanks
Old Apr 24, 2008 | 02:11 PM
Default RE: Engine - Error Code 13
Reset the ECU and determine whether the same code is thrown again before troubleshooting the sensor.
When the engine won' t start, listen for whether the fuel pump primes for a few seconds when the ignition key is turned to ON without cranking engine, and also check for spark at all four plugs.
Old Apr 24, 2008 | 10:06 PM
Madness's Avatar
Thanks for your reply Ron,
After I got this code, I did reset the ECU by unplugging the battery. After this though, the on II position of the key doesn't show lights on the dash board anymore lol Anyway, I don't think I can hear any fuel pump and yesterday I literally put brand new plugs in. The old ones were terrible but still same problem. I can kinda bet on it that it's the fuel pump.
What kinda noise amI listening for?
Cheers
Old Apr 25, 2008 | 12:22 PM
Now that the lights don't even come after you were working on the battery, the battery might be dead or not securely connected.
Old Apr 25, 2008 | 03:20 PM
Yeah, charge the battery and also clean and tighten the battery connectors as suggested by mk.
By the way, an easier way to reset the ECU in the future is to pull out the 7.5A BACKUP fuse in the under-hood fuse box for 30 seconds or so; then re-insert it.
Old Apr 25, 2008 | 05:02 PM
Madness's Avatar
Think I found my problem... I have a Clifford alarm system with the Remote Start feature. The car does not start with the key ingition but starts with the remote button. I was told these Clifford systems are a nightmare and that I should have it removed.
"The remote start feature is a no-go, it just doesn't work. Its supposed to keep the engine running when you exit the car but it probably manages to do it 1 in every 10 times.. the rest of the time its too slow and the engine cuts out. When trying to remote start it just keeps the starter going as it doesnt pickup the engine is running. Me and my mate had the same problem with it "
Still no lights on the dash board though. Maybe I shortened something out whilst jumping the ECU cables, hmmm!
Old Apr 25, 2008 | 07:25 PM
ORIGINAL: Madness
Check whether fuse 15 or 25 under the dash is blown.
Old Apr 26, 2008 | 02:56 AM
Madness's Avatar
Thank you buddy I'll go have a look now Appreciate your help! Gonna try get an electrian to remove my alarm system. Just a bit annoying cos I can't drive it anywhere LOL
zmmerman14
Mar 16, 2012 06:01 AM
JAB1986
19
Mar 10, 2012 07:33 PM
SoCalEX
Aug 30, 2008 11:39 PM
kristop64089
Oct 15, 2006 01:04 PM
sirach38
Jun 19, 2004 10:35 PM
