Engine light came on...
Old Apr 1, 2009 | 12:14 PM
inthezoneac's Avatar
Default Engine light came on...
did the code check, code 67(6 long flashes, 7 short flashes)
Has to do with cat converter. What does this mean? Is it the sensor going into it or the actual cat itself?
I replaced the stock cat with a magnaflow direct fit high flow cat a few months ago, fit perfectly. I did notice the sensor was a little dirty at the time, but I wiped the outside.
So just recently the light came on. At least it's not a bigger problem.
Old Apr 1, 2009 | 06:32 PM
Code 67 generally means the cat is bad, but before replacing, check for an exhaust leak somewhere between the primary and secondary O2 sensors.
firecatf7333
33
Apr 18, 2009 11:05 PM
JakeyMan07
Aug 24, 2008 01:11 PM
EWilliams2000Excoupe
Sep 21, 2007 02:46 PM
94civicexvtec
Jul 11, 2007 09:11 AM
mytsurfer
Dec 9, 2004 07:35 AM
