engine noise
I have a 99 civic ex auto trans with about 165000 miles. About a month ago it started making a noise. It was quiet at first but is now starting to get louder. It started it alittle after i changed the oil. I have checked the oil and it has been maybe 1/4 of a quart or less low, but thats about it. I have searched around the forum and have found a few things, but i'm still not sure what it is. Here is a link so that you can hear the noise. It's not that loud cause i had to use my phone to record it.
Voice-0001.wav
If you need anything else just let me know. My phone sucks when recording sounds and if i get to close to the car the sound is to loud and is distorted. But i can try to get a better recording if you need me to.
Thanks
radeon
Voice-0001.wav
Thanks
radeon
Almost forgot, I was trying to get a better recording of the noise, which if my phone will ever work i can post the link, but it does it even when idling. I guess it did it before and it just wasn't loud enough for me to hear it, but now that it's starting to get louder you can.
It's difficult to help if you don't try to localize the source of the noise. Open the hood while the engine is idling, and locate where the noise is coming from. Post pictures of this area.
Yes there are a lot of engines that will "fit" your car, but an exact replacement would be easiest because you won't have to replace anything else, like the ECU (computer). At least match up the cc size and whether it is VTEC or not. If your problem is only in the bottom of the engine you can reuse your VTEC head on a non-VTEC block.
Edit: Also you might want to get a second opinion on the diagnosis because it seems unlikely to drive for a month with a bad rod bearing and not have the engine throw a rod or otherwise blow out entirely.
I was thinking that to. But, if it is a spun rod then if i find a sohc non vtec 1.6L i can use it and just put the vtec head on like you said. Will it be the same as the engine i have in the car now or will it have less power? This is only the 2nd honda i have ever owed, the first one i only had for a month before it got totaled by an explorer hitting it, so i don't know a whole lot about the cars and what can and can't be done engine wise. So any info would be great.
Thanks
Would this engine work and just put the vtec head on it?
dent: D16Y7
Honda 1590cc (1.6L, 4 cyl).
Engine model D16Y7.
Multi-Point Fuel Injection (MFI)
SOHC.
16 valve.
106 H.P.
FWD.
Thanks
dent: D16Y7
Engine model D16Y7.
SOHC.
16 valve.
106 H.P.
FWD.
