Engine noise when is warm & 1500-3000 rpm
Old Oct 15, 2014 | 07:35 AM
Juanjo_52's Avatar
Angry Engine noise when is warm & 1500-3000 rpm
Hi All,
My civic 2003, coupe, is making some thiking nose from the back part of the engine only when is warm and when is running from 1500 rpm to 3000 or so. It was changed 2 engine seal and oil was changed also to 15w40. Where I live is too hot in summer and not so cold in winter.
Do you have an idea the root cause of this? it would be a signal of major problem
Old Oct 15, 2014 | 08:07 AM
Adjust the valves. The engine does not have self-adjusting valve lifters, so periodically you have to adjust a screw on the end of each rocker arm to compensate for wear.
Also you should not use 15W40 oil except in worn-out engines that burn a lot of oil when you use the recommended kind, which I think is 5W30; 10W30 in very hot conditions.
Old Oct 15, 2014 | 09:15 AM
Juanjo_52's Avatar
my civic has 177k kilometers (110k miles), but engine works fine yet
I will do. I appreciate your quick response
Thank you!
Old Oct 16, 2014 | 03:55 PM
itburnswhenIP's Avatar
honda says 5w20 so use 5w20-5w30 full synthetic would be optimal in your environment.
Old Oct 17, 2014 | 04:54 AM
Juanjo_52's Avatar
You were right MK378, after change the oil to 5w-30 and adjust valves, it works as before. Thanks again
Old Oct 17, 2014 | 04:58 AM
Juanjo_52's Avatar
Thanks ItburbswhenIP, now with 5w20 the high abnormal noise dissapeared. Regards
Old Oct 17, 2014 | 03:48 PM
At that mileage and age of the car it is time to change the timing belt, if it has never been done.
Old Oct 20, 2014 | 04:45 AM
Juanjo_52's Avatar
Yep, I did it 5k kms ago.
Thanks
acf7efi
Oct 10, 2021 03:34 PM
mazterbiruz
Jun 17, 2011 03:55 AM
kellypark
Jun 14, 2011 08:09 AM
Methu969
Feb 19, 2007 01:04 PM
bakertime
Jan 13, 2007 03:05 PM
