Engine replacement advice.
Old Apr 16, 2007 | 08:28 PM
BIMMERGUY's Avatar
Default Engine replacement advice.
Hi there. Just a quick Tech question.
I have a 1998 Civic EX 5sp Non V-tech. That I use as a commuter car. I recently broke a timing belt and destroyed the head/pistons. I have a line on a replacement motor out of a 1996 Civic. Non V-tech motor, under 100k for a good price.($199.00)
Are these motors interchangeable, just as long as I switch the wire harness to the new motor right? I will be using my stock intake/exhaust manifold, and accessories (alt,p/s pump) ????? Or am I going to run into problems?
Thank you.
Kevin
Old Apr 16, 2007 | 08:58 PM
drbyers's Avatar
Default RE: Engine replacement advice.
you may want to check with your local emissions inspections/regulations offiicials first.
some states or municipalities frown upon installing an older model year engines. if they do prohibit it, look for a same model year or newer comparible engine -- even if you have to pay a little more.
Old Apr 16, 2007 | 09:01 PM
BIMMERGUY's Avatar
There are no specific regulations here. They are both OBDII And we have emissions testing every other year anyway.
Old Apr 16, 2007 | 09:02 PM
drbyers's Avatar
you may be good to go then. is the replacement engine from an ex civic as well?
Old Apr 17, 2007 | 09:20 AM
BIMMERGUY's Avatar
I am not sure what it came off of.. The little research I have done seems to lead me to believe that all of the "base engine" of all 1.6litre motors from 1996-2000are the same. Is this correct?
Old Apr 17, 2007 | 11:37 AM
cderalow's Avatar
you're in canada?
checking engine codes should be easiest, dead motor should be D16Y7, new engine should be D16Y7, then it's simply a swap of motor, ECU should work, transmission should be the same... everything should bolt right up/hook right up
Old Apr 17, 2007 | 08:02 PM
BIMMERGUY's Avatar
Why would you assume Canada? My profile says Boston, MA..... Where is the data plate that would state "D16Y7"
Old Apr 17, 2007 | 09:54 PM
bakertime's Avatar
https://www.hondacivicforum.com/m_270258/tm.htm
Old Apr 17, 2007 | 09:57 PM
mxs's Avatar
mxs
ORIGINAL: BIMMERGUY
because you said the car was a "Civic EX Non V-tech" and those don't exist in the US (it's VTEC, by the way).
Old Apr 17, 2007 | 10:08 PM
drbyers's Avatar
pwnt by a canadian chop shop... lol.
