engine revs up and down
hi i have a 1997 civic i stoped using the car for 3 months now the engine revs up & down about 3 techs told me its the idle control valve i have no check engine light on i took the idle control valve out cleaned it and no change got one off another car & same promblem checked all the vacum hoses all ok should i spend $230 on a new speed control valve or look for another option??
Run SEAFOAM. It should clear it up a good bit. It did on mine. Turns out though that TPS was going bad as well. But the seafoam made it around 75-90% better. Its cheap too. There is a great DIY on how to do it in the DIY section, I think x2100 wrote it. Good luck.
i dont know too much about the tps - guess Marty and others could be right on that.
cannot really tell that the vacuum hoses are bad (by looking)
but being a 97, should not need replacing.
i had the problem on an 88, and replaced the vacuum hoses.
it solved the problem but there was also the iacv.
ok i had a freind try the the thing with the gauge no problem with vacume hoses i forgot to say that everytime i leave the car for a couple weeks without use i have to clean out the idle speed control valve and its been like that for the past 3 yrs so i guess its had it
