Engine sounds like a machine gun
Old May 16, 2010 | 02:53 PM
Hank5.9's Avatar
Default Engine sounds like a machine gun
Curious if anyone has seen this before. I will know more within this next week when I can get time to look the car over more closely. Car is my 1.6L 90 Honda HB Si 5 speed. Anytime I accelerate the car stumbles and makes a noise like a machine gun. This happens through any gear, and even in neutral under no load. I know for a fact the bearing in the distributor is going bad so maybe its something as a result of that.
Thanks for your input.
Old May 16, 2010 | 03:25 PM
Oh man, post a video of this. Gotta hear, but it can't be good.
Old May 19, 2010 | 11:14 AM
Hank5.9's Avatar
Sorry, no camera. I once found a reputable Honda parts place that was selling distributors new for around $100. I didn't bookmark that webpage and now I cannot find it again... Anyone aware of the site I am refering too, or a site that has distributors for roughly 100?
Old May 19, 2010 | 12:11 PM
Probably Majestic Honda
Old May 19, 2010 | 03:50 PM
ebay sells them pretty cheap, and ive bought a few they are good.
Old May 25, 2010 | 07:51 PM
Hank5.9's Avatar
Well, I replaced the distributor (because the bearing or bushing was going out) and that didn't fix my engine machine gun issue. I have checked fuel pressure and it was very good, resistance in plug wires were good. Plugs are good. I am now currently checking the TPS and am going to check resistance and sweep to see if all is well, but I tried a quick unplug of the sensor and started it up, and whether its plugged in or not it runs the same..... what should the engine do without the tps hooked up?
Old May 25, 2010 | 08:19 PM
If you unhook the TPS, it'll run like crap for a little then throw a CEL, then the computer will use some default settings to make it work.
Old May 26, 2010 | 07:13 AM
Timing way off will cause terrible knocking.
Take the accessory belts off and run the engine to confirm that the noise really is from inside. If it still sounds like it's from the belt end of the engine it could be the water pump or timing belt tensioner. Have you adjusted the valves?
Old May 26, 2010 | 06:07 PM
Hank5.9's Avatar
after I confirm its not the tps I will check timing. It is not just a noise, the engine actually cuts out when it happens. My apologies for not being very clear.
96Cex
Feb 11, 2009 07:38 PM
Masonn
Sep 16, 2007 03:29 PM
alwaysneednewrubber
Apr 23, 2007 01:06 AM
windcalmer
Dec 21, 2006 02:26 PM
Amanda
Mar 3, 2005 06:23 PM
