engine surges when warmed up...
Old Jun 26, 2006 | 05:30 PM
point78's Avatar
Default engine surges when warmed up...
Need some help here...
90 si crx. runs fine when cold-i.e. less than a few min. When the engine warms up, it surges while under acceleration, and most of the time at steady speed. feels and sounds like it's down a cylinder, but I think its just running real fat when warm. Don't know what to check. Any ideas? (plugs & wires good, air filter is clean, gas is good, no check engine light or codes)
Thanks... B
Old Aug 21, 2006 | 10:55 AM
point78's Avatar
Default RE: engine surges when warmed up...
bump
Old Aug 21, 2006 | 11:05 AM
fglaustin's Avatar
that is usually a vacuum leak.
replace all vacuum hoses - cost about 2 to 3 dollars.
you can look at them - but not tell it.
had the same problem - replace all except for the big one off of the brake booster. should be able to tell if that one is leaking.
Old Aug 22, 2006 | 01:55 AM
RSXt3's Avatar
i had the same prob. w/ my 96 ex coupe
find out where the throttle position sensor is and unplug it
if it doesnt do it anymore thats the prob.
Old Aug 22, 2006 | 05:40 AM
mentaldis0rder's Avatar
same issue when i tried to install a Y8 CAI on a Y7 head.. it was throwing off the Map sensor that plugs into the intake.. good chance that could be bad or not seated properly
PRamon
Jan 12, 2010 09:22 AM
93civicrush
Mar 24, 2007 10:05 AM
TravisR
Apr 18, 2006 09:58 PM
importmech
Oct 14, 2004 09:25 PM
ohbiskits
26
Aug 16, 2004 11:06 AM
