Engine Swap
Old Dec 18, 2006 | 08:10 PM
envirocbr's Avatar
Default Engine Swap
They sent me a VTEC engine for a 1994 Civic with a 1.5...instead of trying to find another engine for this...can I just put on the VTEC distributor on this engine and leave the VTEC controller off?
Will it run?
The car is original NON-VTEC with a NON-VTEC Computer.
Old Dec 18, 2006 | 08:20 PM
envirocbr's Avatar
Default RE: Engine Swap
If this did not make sense let me help
Car: 1994 Civic 1.5 NON-VTEC, Spun Bearing
Engine: 1994 VTEC Engine 1.5
So can this work without having to buy a computer?
Old Dec 18, 2006 | 08:43 PM
seaton05261979's Avatar
The engine will opperate in the same manner as the one you previously had. The vtec option just wont kick in. You can get a p28 ecu and wire up your vtec later if wanted. Theres plenty of info on the adding vtec procedure.
Old Dec 18, 2006 | 08:45 PM
envirocbr's Avatar
Thank you sooo much
I thought it may work cause EVERYTHING bolted right up except for the VTEC connections (Of COurse) and the Distributor!
Old Dec 18, 2006 | 08:50 PM
No prob. Im in the process of going from 1.5 non-vtec to 1.6 vtec. Glad i could help.
chbulldogs11@msn.com
May 27, 2011 09:05 PM
skibum853
Nov 18, 2007 09:40 AM
badboy4life
Sep 1, 2007 08:28 AM
Kingzlei
May 5, 2007 04:06 AM
silvr63vet
Dec 4, 2006 03:55 PM
