engine swap 94 D15B7 into 88 DX?
Old Aug 31, 2012 | 06:28 AM
mtns1234's Avatar
Default engine swap 94 D15B7 into 88 DX?
What would it take to swap a D15B7 (94 Civic) into a 88 Civic dx? Can I use my 88 throttle body intake?
Old Aug 31, 2012 | 08:38 AM
droopy128's Avatar
you would only use the long block, and everything else is re-use from your old motor.
Old Aug 31, 2012 | 12:42 PM
mtns1234's Avatar
I can do that, I'm in CA. Will smog check pass with D15b7 block #?
Old Aug 31, 2012 | 02:17 PM
droopy128's Avatar
Old Sep 2, 2012 | 07:02 AM
mtns1234's Avatar
Thanks Droopy for your write up. I found a donor at pick n pull. 1/2 price sale to.
Old Sep 2, 2012 | 08:00 AM
I put the same engine in my 91, retaining the 91's stock DPFI intake. It is straigthfoward. As I remember there were only some minor mods:
Rewire the radiator fan switch (lead the wires over to the sensor on the thermostat instead of the back of the block),
Rework the small hoses that preheat stuff on the intake,
Tweak the top radiator hose some to make it fit.
The exhaust from the Gen5 will fit but the O2 sensor is different. A 4 wire O2 can be converted to 1 wire by using only the white output wire and grounding the other three.
I think swapping to an engine that is newer than the car is still legal in CA but I don't live there.
Deathstroke97
EK Swaps
Jan 13, 2010 04:08 PM
hydro_yang
Sep 12, 2009 01:18 PM
Derek
Apr 8, 2009 04:00 PM
twdam
ED-EF Swaps
Aug 11, 2008 06:08 PM
chriskatana
ED-EF Swaps
Jun 12, 2006 07:05 AM
