engine and tranny rebuild
Old Jul 4, 2006 | 03:21 PM
regnumirae's Avatar
Default engine and tranny rebuild
I am lookin to rebuild the entire drivetrain .My 89 dx 3door has a d15b2 and automatic.Iwant to rebuild the motor and swap the tranny to a 5 speed.Anybody have any recommendations?
Old Jul 5, 2006 | 01:41 AM
riceburner700's Avatar
Default RE: engine and tranny rebuild
are you gonna do like an aftermarket rebuild with like performance parts or back to oem parts?
Old Jul 5, 2006 | 06:59 PM
regnumirae's Avatar
Yeah,i wanna get away with as much aftermarket stuff as I can ,and still be able to answer to the smog police.Cali is preety strict.I would like to get at least another 40 horses,but don't have the funds for any turbos.
Old Jul 5, 2006 | 09:47 PM
fglaustin's Avatar
are you going to do the head work?
Old Jul 6, 2006 | 07:46 PM
regnumirae's Avatar
Its gotta be able to pass the smog test in a year,so I don't know what I can get away with. Maybe just a good polish in and out. Its got 180,000 mi. on it.
Old Jul 7, 2006 | 08:03 AM
fglaustin's Avatar
i've almost completed my first one. (leak at the oil pan gasket - had to remove).
i am not into the aftermarket stuff - just needed to pass the emissions test.
reason i asked:
i did the head work - and taking the valves out was a real headache.
get the C-type valve spring compressor if you do. i bought the regular one , and there is very very little room to work with it.
Old Jul 7, 2006 | 08:07 AM
AgentofDarkness's Avatar
If your looking to pick up a couple HP with your rebuild i would run a higher compression. Maybe a 10:1 or 11:1 compression. However, when you order the pistons make sure they are CARB certified so the smog police don't give you any trouble. You might also want some forged connecting rods to go with the pistons.
Old Jul 7, 2006 | 08:29 AM
fglaustin's Avatar
i' m finished; but (lol) ; just stock.
started right up -have seated the rings, but big leak at the oil pan gasket (SIGH).
got it back off - will put back today . i hope.
Old Jul 9, 2006 | 11:57 PM
regnumirae's Avatar
it'll be few weeks before I get mine started.I'm wondering if its even worth it to swap,or if I should look for another car.
Old Jul 11, 2006 | 02:28 PM
fglaustin's Avatar
i just did the el-cheapo route.
in car - only did what was needed.
88 civic with 1.5 liter.
saw one bad bearing - little scar down the middle. should have replaced it but did not.
only replaced what was needed.
if you want to know cost - let me know and i will post.
new rings and new seals (right, could not do the rear main), and 2 new valves and new valve guide oil seals.
went to seat in the rings, and it threw out a lot of oil. had to take oil pan back off and redo it (sigh). never thought i could do it that bad !!
also had exhaust leak at the manifold and engine. retightned this time with a torque wrench. still have a small leak. guess need new gasket - i had put the old one back on.
