Equus Tach reading correctly? 2000 civic cx hatch
Old Jan 12, 2010 | 07:39 PM
2000black's Avatar
Default Equus Tach reading correctly? 2000 civic cx hatch
Hi guys,
I just had installed an Equus tach on my 2000 civic cx at a reputable place. The car Is almost entirely stock besides the short ram which I put a few weeks ago. Im not to sure if the tach is reading correctly tho. When idling it reads fine (about 800) but when i accelerate hard off the line im getting only a maximum 4200 reading on the tach. When im cruising at highway speeds I get an accurate reading im presuming which is about 2800 at 120 km/h. I know the car doesnt have alot of power but I should be able to get it up to 5000 atleast going hard off the line. The engine gets very loud but it feels like the tach is not responding. Any help would be appreciated.
2000 civic cx hatch, 5spd, 200km. short ram intake.
Old Jan 12, 2010 | 07:40 PM
2000black's Avatar
Oh I forgot to add, I also read the instructions and set the tach correctly for a 4 cyclinder engine.
Old Jan 13, 2010 | 04:38 AM
It's probably reading correctly. If you're saying the engine sound changes like its going faster but the tach needle doesn't go any higher, something is wrong with the tach.
Since it's not VTEC there isn't much point in revving very high anyway. You should be able to reach 6000 staying in a low gear (not that you should do that while driving, I think peak hp is around 5500). If the check engine light is on for any reason, a lower rev limit will be in effect.
Old Jan 14, 2010 | 08:11 AM
2000black's Avatar
Hi mk,
The tach responds as in if i go higher it will continue to creep up. I believe you are correct since it is not VTEC it will not rev high with ease. The check engine light is on, what is a lower rev limit? thx
Old Jan 14, 2010 | 08:57 AM
DaOne's Avatar
a rev limit is when the computer wont let you rev any higher. ( the needle will just bounce off that limit back and fourth)
Old Jan 14, 2010 | 09:02 AM
This is your problem. Pull the CEL codes from the ECU.
Old Jan 15, 2010 | 11:47 AM
2000black's Avatar
thanks guys. Im gonna pull the codes in the next few days and ill update it.
Old Jan 24, 2010 | 10:27 AM
2000black's Avatar
I pulled out the code at my mech, catalytic converter issue, im not gonna touch it till the next etest, il just have to live with the light on..
Old Jan 24, 2010 | 11:13 AM
What is the specific code?
Old Jan 26, 2010 | 12:33 PM
2000black's Avatar
It was P0420.
