Extremely high compression
but to not be a thread *****.... yes, run some cans of seafoam through there...
https://www.hondacivicforum.com/m_142942/tm.htm
ORIGINAL: mk378
180 is a good normal reading on a stock engine.
At any rate, OP, did you follow the DIY here? Did you make sure to keep the throttle completely open when testing?
Problem solved!
I removed my top end and after investigating found my cylinder full of oil and antifreeze.Turns out I blow my head gasket, hence the reason i was doing a compression test in the first place.
foldingvault
Apr 13, 2011 12:19 AM
95lwrx
42
Apr 6, 2006 06:38 PM
96civicexer
Jan 17, 2006 01:31 PM
