fan switch on a ls
Old Jan 23, 2007 | 12:15 AM
b8teen's Avatar
Default fan switch on a ls
i was wondering if there is a fan switch or if its a relay that turns the fan on. my car is overheating and its because my fan isnt turning on. so what do i need to replace? its a 91 dx hb w/ a 93 ls
thanks
Old Jan 23, 2007 | 05:56 AM
cpl rampage's Avatar
Default RE: fan switch on a ls
there is a fan switch on the thermostat housing that might be going bad, there should also be a relay for the fan in the underhood fuse box,
the first thing i would check is the fan, make sure it will spin, and if it does, then hook it directly up to a 12 v source and see if it turns on, if it does then check the relay, if thats good, check the switch for continuity when its hot, and if that works, check the continuity of all the wires and connections
Old Jan 23, 2007 | 08:45 PM
b8teen's Avatar
thanks, ill check it tommorrow
Avast1983
Jun 14, 2011 01:16 AM
anivast999
May 14, 2011 06:15 PM
alex_dodge1977
Oct 4, 2010 05:28 AM
madmurray
Nov 8, 2007 10:45 AM
lillyrat
May 22, 2007 09:31 PM
