faulty sensor?? MAP/O2?civic
Old Oct 22, 2006 | 02:42 PM
chrisspliff's Avatar
Default faulty sensor?? MAP/O2?civic
Hey. Need help with my 92 civic hatch.
Started it up this morning fine... after it warmed up (right about the time the choke would disable) it stalled. Car would start right up but only idle for about 3 seconds. Seems like gas or oxygen was being cut off once the car was started. Thinking it was a sensor or something i disconnected a sensor on the top left of the manifold. I think its the map sensor... anyway my car started right up but was running rough. Didn't stall at all. I then reconnected the sensor and now cannot even get the car started. Anyone know what the problem could be? (It was a very cold morning when i tried all this) Thanks
Old Oct 22, 2006 | 07:53 PM
fglaustin's Avatar
Default RE: faulty sensor?? MAP/O2?civic
can you read the ecu without the instrument?
if so, turn the key to ON and read the ecu and figure out the code.
should be one if the MAP sensor is bad.
jstirn
Jun 24, 2011 07:04 PM
denisholden
Aug 12, 2007 09:31 AM
fukengruven00
Mar 22, 2007 09:55 PM
dj_ipirate
Dec 19, 2005 07:14 AM
00sithrottle
May 12, 2005 10:25 AM
