Firing Uneven
Old Nov 22, 2007 | 03:59 PM
Jaynik's Avatar
Default Firing Uneven
1994 Civic Lx,
The car has a misfire that you can hear, makes it idle erratically.
Plugs, Wires, Cap, Rotor replaced, no fix.
If you hook up a timing light to it you can actually see the flashes going out of rythm, which means it is firing pretty poorly.
What do you think, Distributor? Control Module?
Old Nov 22, 2007 | 06:01 PM
Default RE: Firing Uneven
Is the Check Engine Light ON? If so, retrieve the code. One possibility is that you have a faulty TDC/CRANK/CYL sensor in the distributor.
Old Nov 22, 2007 | 07:32 PM
Jaynik's Avatar
Not a code in sight. You can hear and feel it misfire tho, I dont think this model has a knock sensor but thats that it sounds like. A knock or a stumble.
Old Nov 22, 2007 | 07:59 PM
Perhaps the coil or igniter unit in your distributor is intermittently faulty?
The MAP sensor and fuel injectors are other possibilities, but problems with these components should also turn the CEL ON.
Finally, a faulty EGR valve might not turn the CEL ON but could produce your symptoms.
Old Nov 23, 2007 | 12:07 PM
Jaynik's Avatar
I think we have found the problem. We got the dizzy off and the shaft is rough to turn and would get stuck, so I suppose it would seize and that would cause a misfire. Waalaa!
Old Nov 23, 2007 | 12:48 PM
Glad to hear that you found the problem.
uwintoday
Jan 7, 2009 08:38 AM
CrackerJack
May 10, 2007 04:54 PM
Infraeon
13
Mar 5, 2007 09:10 PM
chemistry
14
Jul 11, 2006 01:38 PM
Spartan21
Dec 23, 2005 03:10 PM
