front end problem
Old May 16, 2007 | 05:56 PM
compo1's Avatar
Default front end problem
had a problem with cv axle and decide to replace all the front end components at 105k...got everything back together and i have a problem..the back of the steering knuckle is making contact with the strut spring...i thought i followed the directions but something is not right..the upper control armhangs in a downward manner...shud it be more level..i also noticed that when i tightened the tie rod end, the castle nut went beyond the hole enough so that the cotter pin does not contact the nut when you push it thru the stud... i lifted up on the control arm b-4 doing this and let down on it after tightening....the fork and strut went in correctly so i think it's the height..in the manualsdirections they talk about simulating ride height...how is that done...maybe that is my problem
Old May 16, 2007 | 08:23 PM
ej6buddy's Avatar
Default RE: front end problem
i'm having a hard time follow your text, try and post up a picture, then i can help you, i just recently rebuilt my cv joint, so it's the same process.
blackflames
Dec 19, 2008 05:27 PM
Spark
May 20, 2007 10:10 PM
LuvCars
Jan 29, 2006 06:35 PM
omgxitsxaxhb
Feb 12, 2005 02:04 AM
dalifts
Sep 15, 2004 10:00 PM
