front lights only bright goes on who can help?
hello, today i bought a new pair of front lights cause only my bright went on with the old lights, but when i bought the new ones and changed them the diem still doesn't go on what could the problem be?
You didn't say which model year. Most have 4 headlight fuses under the dash, one for each beam (left low, left high, right low, and right high). Probe the test points on the fuses (measure voltage from each point to ground) with the light switch in each position. The way it works is the light switch powers up either the two low or the two high fuses, then that power goes to the lights. If the low fuses don't get power at all, the light switch is probably bad. If there is power on one test point of a fuse but not the other, the fuse is blown.
it's 1997 EK, the problem is my car had a H22 in it before i bought it now it has a d15, i can see the fuse box but i cant tell wich one is for the lights the sticker is gone can i find something on the net how to know wich fuses are for the headlight?
JayVee
15
Dec 17, 2009 03:38 PM
