front motor mount?
the center bolt that runs through the motor mount won't move. if the bushings were cracked or torn wouldn't the center bolt move up and down?
the center bolt i'm talking about runs through the hole in the middle of the circle in this picture
http://static.1aautoimages.com/parti...00008/main.JPG
If you are trying to remove it with a ratcheting socket wrench, it is going to be tough I would think. I would suggest using an impact gun. Also, I would get a jack under the motor in order to help relieve the weight off the mounts for the bolt to come out easier if needed. If you jack up the motor, be sure to use a piece of wood between the jack and the oil pan to evenly distribute the weight so the pan isn't damaged. I have a picture floating around of me using a Haynes manual for this, but I can't find it for some reason. haha
EDIT - Found it
PCollen
Oct 19, 2014 07:44 PM
