fuel cut off switch??
i took my plugs out yesterday to do a compression check on my h22. after i put all the plugs back in i cranked it over but its not firing. i started taking a look at it 2day and managed to lock my keys in the car (but thats another story lol) the guy who came out to get my car open said it could be a fuel cut off switch/reset switch? could anyone tell me where this is on my car? i've got an eg esi h/b
If there is a fuel cut off switch, you would have had to bump it to turn the fuel feed off. Chances are if there is one in there, it's probably hidden really well (thats kinda the point of having one) so I guess just search around and see if you can find it
ok thanks for the reply. i just checked to see if it was sparking but theres nothing. im pretty sure its not the dizzy etc. as it was running fine before i took the plugs out. could something have shorted as i cranked it over without the plugs in?
your more than welcome to insult my intelligence lol, im fairly new to cars and i wont be suprised if its something stupid that i've missed. ye everything is all hooked up and its turning over but no spark
"The reason why you should always use the tester is because you can damage the computer if the spar plug wire is not close enough or grounded to the plug or engine block. The tester is designed with the correct gap for the spark to fly across."
i just read that in another thread from a while back. when i did the compression check i didnt use a tester and just left the leads hanging about. could i have fryed my ecu?
ORIGINAL: Forty04
Not intending to insult your intelligence, but 75% of the time, it's something stupid that causes issues..
