Fuel Filter Question
Whats the best way to relieve pressure on thte fuel line so i change the fuel filter?
RE: Fuel Filter Question
Opening the gas cap might do it. That will take pressure off the system, but the weight of the gas in the tank/line will probably force some gas out when you crack the fittings. Usually, the fuel just leaks out till the level equalizes. I haven't even looked for my fuel filter yet, so forgive my ignorance to its location. If it is high up (above the tank) not much will come out. If it is under the car, the line from the filter to the engine will drain and more gas will leak out.
allow the engine to cool and take the gas cap off.
and wait till your tank is low on gas too. this should releave some of the pressure in the line
