Fuel Filter Question
Opening the gas cap might do it. That will take pressure off the system, but the weight of the gas in the tank/line will probably force some gas out when you crack the fittings. Usually, the fuel just leaks out till the level equalizes. I haven't even looked for my fuel filter yet, so forgive my ignorance to its location. If it is high up (above the tank) not much will come out. If it is under the car, the line from the filter to the engine will drain and more gas will leak out.
kenji51590
Feb 24, 2011 05:24 PM
Hailchristian
Jun 23, 2008 12:49 AM
cdansley
Apr 22, 2006 11:52 PM
