Fuel reset button
Old May 6, 2010 | 03:38 AM
Does the engine shaft rotate when you turn the key, or not? Look at the pulleys on the left (driver's) side. If it does, do the spark test.
Jury-rigged wiring should be restored to stock. There's no reason to add wires to the distributor for a sound system. (Maybe it's just a ground wire, if it goes to one of the bolts on the engine rather than into the distributor itself. Extra ground wires don't hurt anything.)
Old May 9, 2010 | 07:53 AM
MarymP97's Avatar
mk378 - my son watched while I turned the key & he said he saw the pulleys turning. I don't have a spare spark plug to do the spark test. (I can't get to town to get one). I'm thinking I will have it towed tomorrow to a mechanic about 5 miles away who has worked on the car before & I trust. Could you, or anyone else, maybe give me an idea of what you think it would/should cost to replace spark plugs/wires, and or ignition coil, and/or starter solenoid - or possibly any other scenario you think possible like this? I know it could be anything and could cost anything. But I'm really thinking its not getting fire/spark from what I've read & done so far. If someone could let me know what I'm possibly looking at - major cost vs. medium cost vs. relatively inexpensive cost - it would go a long way to helping me decide if I can get it fixed now, or have to wait til my next pension check comes in June 1. If I haul it to the shop, and I can't afford to have him fix it, or, he can't get it done in one day, then I'm stuck there, or, have to walk the 5 miles back home. Any ideas regarding what expense could be would be appreciated. I just have no experience at all to base a guess on. Thanks!
Old May 9, 2010 | 09:11 AM
If you can't get a spare spark plug, then remove one existing plug and do the spark test for each plug wire as described in the Spark link in my signature.
Old May 11, 2010 | 10:28 AM
MarymP97's Avatar
The shop just called. They changed the plugs. They also told me for some reason, 2 of the cylinders had too much gas in them. I told them about thinking I ran out of gas, putting gas in, etc. and they said No, it was a matter of too much, not too little. They don't know why. I don't have a clue, but think somehow maybe I flooded it trying to start the car so many times? They also discovered a small leak in my radiator, which I had pretty much figured out already since I had had to add coolant to it a couple of times. They are charging $75 for what they did today - plugs, cleaned up the cylinders, filled the radiator, I think new plug wires too - I think is a good price. To replace the radiator they said will be about $315, and I guess that is a good price too. They said to just stay on top of it til I can bring it back in June. That will be easy, since I don't drive that much. Thank you everyone for your help.
Justin Gomez
Jul 27, 2013 05:04 PM
mrtimepa
Jun 20, 2013 08:33 AM
00IntegraLS
Mar 14, 2008 03:12 PM
addiction2bass
Nov 4, 2007 12:54 AM
campbuds
Jan 10, 2006 11:11 AM
