GAS PEDAL
I Recently bought a 97 civic Lx. 100k Mileage.
when i press the gas pedal it's not smooth. I had to press little hard. sometimes it gets jammed and when press it hard the car just Zooms.. I am Quiet knew to Cars. This is my first car. Is this a minor problem ? What will be the possible remedy. thankyou. |
RE: GAS PEDAL
you mean "NEW" to cars right? lol just giving you a hard time. But i used to have that problem with my old Eagle. Try to make sure that everything is well lubricated down by the pedals.
RE: GAS PEDAL
either your pressing too hard, or theres something getting stuck.
RE: GAS PEDAL
If it is sticking just when you first start to go off of idle, you probably just need to clean the throttle body and throttle plate. Sticking throughout the range is likely going to be the cable from the gas pedal to the throttle body.
RE: GAS PEDAL
If you are that new to car... it probably means you'll get used to it. I did the same, my girlfriend did the same.. Actually just trying another car (one that she never drove) makes her do the same thing..
RE: GAS PEDAL
our van does it, i'm pretty sure it just needs to be cleaned and lubed.
i don't think he means the sensitvity of the pedal, but it getting stuck. |
RE: GAS PEDAL
I had that issue when I first got my civic... it got better, and now i dont even notice it... hope that gives you hope, lol
