Gear shift wiggle
Old Aug 24, 2013 | 09:54 AM
David_S's Avatar
Default Gear shift wiggle
I need to replace the bushings in my gearshift linkage. Anyone know where to get the ones for up by the transmission?
Old Aug 24, 2013 | 11:10 AM
David_S's Avatar
Well I think I found the part.
ROD, CHANGE for 1990 HONDA CIVIC HATCHBACK|54201-SH3-A04
It is #16 in the diagram.
Looks like the only way to get it is to order the whole arm\rod\whatever.
Old Aug 25, 2013 | 04:35 AM
You can look into something like energy suspension shifter bushings. No complaints on my end except it is messy to install
Old Aug 25, 2013 | 07:32 AM
David_S's Avatar
Got a link?
Old Aug 25, 2013 | 07:38 AM
David_S's Avatar
Never mind I found what you were referring to, and yes I could use some of those but thats not my issue. I need it on the other rod where it attaches to the rod coming out of the transmission. Some people just don't realize what a little oil leak can do to the rest of their suspension/shift bushings.
Old Aug 25, 2013 | 06:55 PM
droopy128's Avatar
There is no bushing of the connecting rod to the tranny.. only the pin.. or are you refering to the seal on the shift rod where it attach..?
Old Aug 26, 2013 | 01:47 PM
If you're talking about the u-joint thing, it is riveted together so it's officially supposed to be replaced as a unit along with the whole rod. The aftermarket kits probably have you drill out the rivets and install bolts.
Old Aug 27, 2013 | 02:16 PM
David_S's Avatar
mk378, Well I cant find anyone that still stocks the unit. I haven't been able to find the after market kit either. Do you happen to have a link?
theRDRman
Jan 2, 2012 08:37 PM
rydnlow1120
Jul 25, 2007 01:14 PM
mybrokenblinker
Oct 30, 2006 10:29 PM
grnrivergirl
Sep 1, 2005 09:12 PM
phriston
Apr 11, 2005 05:24 PM
