gsr into del sol
Yes it will fit. Some adjustment may be needed, not sure on that though. My friend did the exact same swap into his girlfriend's Del Sol. I believe it's a b16a that's in the GSRs. The two words "very" and "fast" describe what it became well. Tell your boy to have fun Biskits. Late.
b18c/1 is the gsr motor....b18c5 is the type-r motor
the gsr motor has 180 hp and handles modding a bit better.. but is missing the lsd on the tranny.
the type-r has 200hp and has a hyd. lsd tranny
the b16 is the civ si motor..not the gsr
Yeah, that's pretty much it. But the C is actually from the JDM Teg SiR, and makes 180 hp/ 130lb/ft., while the C1 is the USDM GS-R motor making 170 hp/ 130 lb/ft. Subtle difference, but a difference nonetheless.
And the B16/A comes in quite a bit more than just the Si.
all iv seen b16a's for are different year si-r's...
the b16b's is the civic type-r motor....
i dont get what ur saying about the c motors kappa..
the 18c comes from the teg gsr motor and the 18c5 or c(r) is the teg type are motor..
I'm just saying that the B18C is actually a JDM engine from the Integra SiR, while the B18C1 is the from the USDM GS-R. You're right about the B18C5.
And the B16/A/A1/A2/A3/A4 (all fairly similar) came in:
-4G JDM Civic SiR's and the EDM Civic VTi, which are pretty much the same
-5G JDM Civic SiR and SiR II
-6G JDM SiR II, EDM VTi, and USDM Si
-4G JDM CRX SiR and EDM CRX 1.6 VTi
-5G JDM Del Sol and CRX SiR
-5G USDM Del Sol VTEC, EDM Del Sol VTi-T
-2G JDM Integra Xsi/Rsi
Not sure I got 'em all... I might've missed something
