Gurus out there? Crank, won't start - obvious has been done
'95 Honda Civic DX, 142K mi
Cranks but will not start, only when cold (< 50F). Repeatable problem. Car runs perfect once it starts. Tests done when not starting: Spark is OK. Fuel pressure on FI rail is OK. 5V on MAP sensor. Main relay clicks good, fuel pump hums nicely. Work I've already done: New ignition coil New igniter module New fuel filter New battery Resoldered main relay connections Cleaned ground connection on thermostat housing Once it warms up in the afternoon, car starts immediately. Never stalls -- runs great. Dead as a door nail the next morning, if cold. No CEL, no diagnostic codes found. Any help is appreciated! |
RE: Gurus out there? Crank, won't start - obvious has been done
I'm no Guru, but you might want to check the Fast Idle Valve:
http://img218.imageshack.us/img218/8...ure0333tg5.jpg |
ORIGINAL: RonJ I'm no Guru, but you might want to check the Fast Idle Valve: |
+1 to the fast idle valve "(IACV)"
also you could test out the coolant temp sensor... |
Iknow you say spark is o.k but check out the cap and rotor for carbon pile up and cold enough temps it could be enough resistance not to start
