Gurus out there? Crank, won't start - obvious has been done
Old Jan 10, 2008 | 04:12 PM
greasemitts's Avatar
Default Gurus out there? Crank, won't start - obvious has been done
'95 Honda Civic DX, 142K mi
Cranks but will not start, only when cold (< 50F). Repeatable problem. Car runs perfect once it starts.
Tests done when not starting:
Spark is OK.
Fuel pressure on FI rail is OK.
5V on MAP sensor.
Main relay clicks good, fuel pump hums nicely.
Work I've already done:
New ignition coil
New igniter module
New fuel filter
New battery
Resoldered main relay connections
Cleaned ground connection on thermostat housing
Once it warms up in the afternoon, car starts immediately. Never stalls -- runs great. Dead as a door nail the next morning, if cold. No CEL, no diagnostic codes found.
Any help is appreciated!
Old Jan 10, 2008 | 04:52 PM
Default RE: Gurus out there? Crank, won't start - obvious has been done
I'm no Guru, but you might want to check the Fast Idle Valve:
Old Jan 10, 2008 | 05:08 PM
ORIGINAL: RonJ
Thanks for posting that -- I'll check it out!
Old Jan 10, 2008 | 05:28 PM
JETSPEED333's Avatar
+1 to the fast idle valve "(IACV)"
also you could test out the coolant temp sensor...
Old Jan 10, 2008 | 06:38 PM
Stocker's Avatar
Iknow you say spark is o.k but check out the cap and rotor for carbon pile up and cold enough temps it could be enough resistance not to start
zerojett
Oct 18, 2011 03:01 PM
abstract23
Oct 9, 2009 08:20 PM
drbyers
Jun 9, 2007 11:33 PM
snosurfa7
13
May 18, 2007 02:08 PM
clutchjunkie
May 29, 2005 01:21 AM
