half shaft problems
Old Nov 20, 2010 | 05:58 AM
crusty juicebox's Avatar
Default half shaft problems
Hi everyone,
Last night i replaced my passenger side half shaft on my 97 civic dx. I had been hearing alot of clunking noise from it and the boot was torn completely arond the cv joint. everything went fine untill the test drive. i drove the car about a half mile and went to turn around when the transmission quit turning the wheel. I had to have it towed back to my house. Any help would be great! Thanks
Old Nov 20, 2010 | 06:19 AM
Sounds like the new one wasn't pushed all the way into the transmission until it locks. A common problem. Also check that you have the lock ring on the end of the new one.
Old Nov 20, 2010 | 06:29 AM
Default thank you so much
clip is on the new shaft. i will schwack it with a rubber mallot. just wanted to make sure it wasnt a miss-diagnosed problem. also the new half shaft has an extra rubber ring around it that my old one doesnt have. new engineering?
Old Nov 23, 2010 | 02:53 PM
all is well. thanks!
Ska-T
Sep 29, 2014 11:14 AM
asechrist
Aug 12, 2009 07:16 PM
mr honda
Mar 8, 2008 07:47 PM
classiccarsrule85
Apr 6, 2007 08:30 AM
