Halogens & HID
Does anyone have specs on the power usage of the headlight system on a 2K8 Honda Civic Hybrid and HIDs with 4300K? I'm wanting to compare because the electrical system on a hybrid is different and just want to make sure it's not overwhelmed by the 4300. Thanks.
well dont have the specs. BUT HIDs will pull some juice to fire the bulbs up BUT after they fire up initialy they are suposed to use less power than standard bulbs. so i dont see any problem with them in a hybrid.
The color temperature of the bulb is just the color of light that it makes. They're all 35 watt bulbs so they all use the same amount of current. I think it would work fine. The stock halogen bulbs are about 55 watts, so you're using less power once they are warmed up. Unless the startup surge is enough to blow the fuse, which would also be a problem with non-hybrid cars, it's going to work.
zspeedzkwy
Jan 4, 2008 11:45 PM
jwsimons
Feb 23, 2005 12:10 AM
