harmonic ballancer
Old Apr 5, 2005 | 09:55 AM
gonescootin's Avatar
Default harmonic ballancer
simple question, which way does the bolt turn to take off the balancr on a 94 civic?
And how do I keep the motor from turning to looseing it. Thx.
Old Apr 5, 2005 | 12:12 PM
97CivicEX's Avatar
Default RE: harmonic ballancer
I am not 100% sure, but all the Harmonic balancer bolts I have removed have been of conventional thread. Clockwise to tighten, CCW to loosen. Does your car have a harmonic balancer, or is it just the main pulley? Anyway I am in the same situation. I am doing the timin chain and need to take it off. The only way I can think of is with a strap wrench(the chain kind) and an impact tool or breaker bar.
Old Apr 5, 2005 | 07:42 PM
firzout's Avatar
I just replaced my 94 civic's timing belt. First of all it is not easy to loosen. many times you will brake the crank bolt!! Anyway, what I did was a placed an extention bar (6") in one of the wholes turned the pulley until it was catching under the oil pan, and used an impact gun. You will need to hit it for a while. I had you use a braker bar with and extebtion bar ( broke the extention bar) but was able to use the impact after that to lossen it. You need to be careful not to force the bar too much and damage the pulley, remember that you have another bar in one of the whole keeping the pulley from turning. good luck let me know if that works for you.
Old Apr 5, 2005 | 08:57 PM
sacicons's Avatar
dont use extensions on the impact, they absorb too much of the torque, itll be hard as hell to get it loose that way.but what hole did you stick the extension in to lock it?
RicoP
Nov 4, 2009 10:40 AM
camerenyates
Jul 21, 2009 02:50 PM
linkz761
Jun 25, 2009 07:54 AM
camerenyates
Jun 21, 2009 02:47 PM
BCivic93
Jun 20, 2007 07:51 PM
