hatchback wont start
Old Sep 9, 2010 | 04:00 PM
paddywack89's Avatar
Default hatchback wont start
my friend and i put a d15b1 in my 93 hatchback to replace the d15b7 that i broke the camshaft and gouged the head on (dont ask lol). dropped it in, replaced the injectors and it started right up, we decided to check the compression just to be safe, compression was good, put everything back in and now it wont start...
my friend says its the distributor but i dont see how that would have messed up...?
Old Sep 9, 2010 | 04:04 PM
Cranking the engine with the plug wires disconnected can blow the coil. Those coils don't like to fire into an open circuit. (To run a compression test, you should unplug the low-voltage supply plugs to the distributor, so the coil doesn't try to fire. Or ground out all the spark plug wires. Or jump the starter so the engine turns with the key OFF.)
See if you have spark now, if not, replace coil.
David_S
Oct 24, 2013 10:06 AM
EncounterJake
Jan 11, 2013 01:10 AM
tren295
Jun 13, 2012 11:12 AM
bmelloh
May 16, 2009 08:01 PM
MistaGlock
37
Mar 1, 2008 02:15 PM
