Have a head gasket question.
1993 1.5L D15 engine with about 90,000 miles. About 2 months ago the head gasket gave up and I was getting antifreeze into one cylinder so it was over heating. I pulled the top end and had the head reworked at a machince shop. (Valve job and shaved flat.) I put it all back together with an OEM Honda head gasket and it ran better than ever.
Fast forward to this weekend. It started to overheat again. I just pulled the plugs to do a compression test and when I went to crank it to test the first cylinder antifreeze squirted up out of one cylinders spark plug hole. Has to be the head gasket again.
My question: Is there an aftermarket head gasket that might hold better or do you think the block deck has a flatness problem? When I pulled the head the last time I put a straight edge on the block deck and it seemed to be OK.
I'm trying to decide if I want to put another head gasket on or call this motor history.
How about this stuff? Does it work? Worth trying? http://www.steelseal.com/eng/home.html
herpsunlimited
Jan 7, 2008 07:49 PM
95lsvtec
Feb 14, 2006 11:46 PM
civicpimpinsc
Jan 7, 2006 07:58 PM
