Headlight stopped working...while trying to aim
Hello,
I was trying to aim my headlights and suddenly the headlight that i was trying to aim turned off...
First i thought that i probably have blown the bulb or something....so i changed the bulb and it was still not working....
So i put the stock headlight back on...and it was not working either...
Its the driver side headlight....the low and high beams are not working but the indicator ones are working fine....
So wat happened here? did i blew up a fuse or something somewhere? and yes then which one and where will i find it?
thnx for any help
thnx for any help
i would check the fuses first, then if they are good(replace em anyway) i would use a voltmeter to test to see if there is power going to the socket
ORIGINAL: Fiirkan
prb solved cheers
just wondering...what caused the fuse to blow like that? i was only trying to aim the headlight?
ORIGINAL: CiViC_NaTioN
hey thnx bud it was the fuse
prb solved cheers
ORIGINAL: Fiirkan
prb solved cheers
95turbocivic
Jun 13, 2011 10:14 AM
pearlwhite94ttz
Jan 21, 2010 03:34 PM
pheng617
Feb 12, 2009 07:30 AM
AdamC
Jun 2, 2004 04:08 PM
