Headlights flashing on and off
Old Jan 21, 2014 | 02:10 PM
Keith Richard M's Avatar
Default Headlights flashing on and off
Bought a 1998 Honda Civic DX hatchback in 2007. It's been a great car! Until recently the headlights would turn on automatically when starting the engine. Now they do not. Instead the headlights flash on and off for a short while driving. You can hear the mechanism clicking under the dash somewhere. There doesn't seem to be any other electrical problems other than the rear window wiper stopped working about a year ago (yes I checked the fuses). Alternator was replaced about 2 years ago. Car starts, runs and drives perfectly except for the headlight issue.
Old Jan 21, 2014 | 07:58 PM
There must be some aftermarket wiring, because in stock condition the headlights are not designed to come on automatically when starting the engine. Unless its a Canadian model with DRL.
Old Jan 23, 2014 | 01:25 PM
SPLAT's Avatar
Does it have an alarm?
Old Jan 23, 2014 | 03:34 PM
itburnswhenIP's Avatar
try replacing the the relay switch there very inexpensive and can be found at any parts store.
Old Jan 24, 2014 | 08:48 AM
Yes, it does have an alarm.
Old Jan 24, 2014 | 04:37 PM
SPLAT's Avatar
Is it a Honda Alarm or aftermarket one?
Old Jan 25, 2014 | 12:13 PM
I was told when I bought the car that it's a factory alarm. Requires double click on ignition switch to disengage. Didn't come with fancy key chain clicker.
Old Jan 25, 2014 | 12:15 PM
I believe the original owner purchased this car new in Vancouver, BC.
Old Jan 25, 2014 | 02:25 PM
The DRL model is known for problems with the DRL controller, which I think is mounted behind the dash near the glove compartment. It can be "rebuilt" by removing it from the car, open the box, and resolder all the conections on the circuit board like you would do a main relay.
Also I think you can just disconnect it and then the lights will be controlled strictly by the light switch like the USA model.
Old Jan 27, 2014 | 11:03 PM
Thanks a lot for your help! I found the DRL box by removing the glove compartment and sure enough that's where the clicking is coming from. Mystery solved!
fongcom
Feb 9, 2011 03:02 AM
myaman
Mar 5, 2010 09:51 AM
Cosworth
Dec 15, 2008 05:35 AM
cfy30
Oct 13, 2006 01:05 AM
