Help ,Cylinder Head Conversion
Old May 13, 2007 | 11:12 AM
fmn716's Avatar
Default Help ,Cylinder Head Conversion
Hi Guys
I Need some help I have a 12v et2(Engine code)1.8l 1984 Honda prelude 2gen
Its bore/stroke is 80mm and i want to convert the head cylinder to a 16v vtec
using a d16a head and i would like to know if it has the same stroke/bore.
By the way my pistons have 4 valve reliefs so its possible to convert to 16v.
If this cannot be done what other cylinder head can I use with the same bore/stroke,
it doesnt have to be vtec,but it has to be 16v.
I am going to use weber 45 dcoe because they are easy to tune and converting to fuel
injection is too much work, don'tworry if the head is designed for FIit will work.
Thanks guys hope to hear from you soon
whitecivicex
Apr 18, 2011 12:40 AM
WellFedHobo
Feb 25, 2010 03:56 PM
EJ6515
Jul 11, 2009 04:08 PM
sway2003
Dec 27, 2006 07:33 PM
JamesWatts
May 30, 2006 01:03 PM
