HELP!! How to route a cable from engine to the instrument panel
Old Aug 6, 2006 | 07:52 PM
HaZe89's Avatar
Default HELP!! How to route a cable from engine to the instrument panel
hey people im super stress cause i buy a LED and some wires to instal my vtec ligth so when vtec kick in i notice in my instrument panel the problemis that i cant find a way to route the cables from the vtec solenoid wire to the instrument panel. first i cant find a way tru the firewall so the i cant get the cable inside the car, the second is that i cant find the second way once in the car to route it to the guages?
PLZZZZZZZZ i beg you can someone help me with this?????
Old Aug 6, 2006 | 07:57 PM
blkwidow's Avatar
Default RE: HELP!! How to route a cable from engine to the instrument panel
if you take out the battery box you will see that the harnes from the motor goes in under it that is a great location i used it to run all my stereo wires and my boost controller. just a suggestion there are 3 bolts to get it out after you remove the battery.
Old Aug 6, 2006 | 08:25 PM
ludakrishna420's Avatar
use the ECU inside the car. Its much easier.
https://www.hondacivicforum.com/m_24.../tm.htm#248922
Old Aug 6, 2006 | 09:54 PM
HaZe89's Avatar
Thanks people................very much i feel much better. well ill try to find the vtec wire in the ECU of not then ill try to find removing the baterry. the point is that i already peeled off the solenoid wire so i guees if i find it in the inside ill just put some tape
. hey by the way what kind of LED i way use? i mean how many volt.. what wattage that cable has?? cause if ill buy a 2v LED probabbly it would blow or something
Old Aug 7, 2006 | 11:41 AM
be sure to use a resistor if it is not already built in.
Old Aug 7, 2006 | 04:11 PM
HaZe89's Avatar
thanks a lot for rememberign me that.what kind of resisttor should i use ( the volts) and what LED im thnkin of usgin 12v LEDS\
i have a 95 civic
other thing.... i try to find the green cable with yellow stripe under the passanger seat you know up there like below the airbag .. but later just come to my mind to take of the panel below the radio and i look up there and i see a thin green wire with a yello stripe..is that vtec??? where the ecu is by the way???
Old Aug 7, 2006 | 10:34 PM
fglaustin's Avatar
if you were attaching a troubleshooting light to the battery - would use 12 volt bulb. think would use 12 volt led.
cannot help with vtec.
ecu on cars is either under the seat or if like my honda it is under the floor below the dash where the passenger's feet would be.
Old Aug 7, 2006 | 10:47 PM
http://www.radioshack.com/product/in...entPage=search
this is what i got for my VTEC light. It has a built in resitor so you just have to worry about grounding and hooking it up to the vtec wire. btw. from your sig i noticed that you have a pre 96 civic. This means that your vtec wire might not be green/yellow. But i'll double check. Furthermore, you'll looking at the wrong place. The Vtec wire would be next to the kick panel not near the speaker. Its next to the ECU.
http://www.honda-tech.com/zerothread?id=1171263&page=1
joeD2J
Apr 3, 2011 02:18 AM
brett1420
May 17, 2010 04:20 AM
thebadgator87
Jan 16, 2007 08:28 PM
HaZe89
Aug 6, 2006 07:57 PM
The Scales
Feb 16, 2006 02:16 PM
