help me please.
Old Mar 19, 2010 | 02:06 PM
oatnut's Avatar
Unhappy help me please.
someone please diagnose this.
http://www.youtube.com/watch?v=z3PiwdLoJXY
it's 95 honda civic ex coupe 1.6L automatic.
my wife overheated and smoked it.
radiator was cracked and not much coolent were left in the system when i took this video. no leaking anywhere. spark plug wire tube is stucked to sparkplugs and cylinder. timing belt looks good. no oil coolent mixture neither in oil-pen nor radiator. loss of power.
plz help. i'm dying here.
-cody from texas-
Old Mar 19, 2010 | 02:33 PM
Wooooooow. That has the sound of a bad engine. I don't know if that's bottom end or top end or both.
Are you 100% sure that the coolant system was bled properly after the radiator was replaced? Engines will make some strange noises when there is air in the system. Also, with an overheat that bad you might want to have the head checked for warpage.
And check the oil.
Old Mar 19, 2010 | 02:34 PM
StifflersMom's Avatar
Cat Fuсker
You need a leakdown test.
Old Mar 19, 2010 | 02:46 PM
oatnut's Avatar
what would be the proper procedure to bleed rediator procedure? How I did after installing new radiator was
1. cap off
2.poor in coolent into radiator
3. same to reservior
4. squeezed botom hose rapidly
5. loose the bleed hole on engine
6. let the engine warm up( 5 to 10min.) let it bleed until i c no more bubble
7. tighten it.
8. shut down car
9. wait to cool
10. put some more coolent
11. start the car to warm up
12. put more coolent to radiator.
13. close radiator cap on.
am i doing something wrong?
i wanna thank u all for trying to help me.
it means alot.
Old Mar 19, 2010 | 02:47 PM
The front end of the car should have been up on jack stands to force the air to bubble out through the radiator.
Old Mar 19, 2010 | 02:48 PM
oatnut's Avatar
by the way, on that video, engine surges. it's doing that on it's own. it takes 3 to 5 trys on ignition to start this car and what u c on the video happens.
Old Mar 19, 2010 | 02:50 PM
oatnut's Avatar
besides that, am I doing everything right ?
"""The front end of the car should have been up on jack stands to force the air to bubble out through the radiator. """
Old Mar 19, 2010 | 03:02 PM
Seems like it
It just sounds like something is grinding. That's why wanna know how much oil you have in there.
Old Mar 19, 2010 | 04:41 PM
nasoj007's Avatar
Kinda sounds like the water pump is toast...
