help with my projector headlights
Old Aug 17, 2006 | 08:48 PM
lookitzxai's Avatar
Default help with my projector headlights
I recently got a projector headlight for my 95 civic dx.....but the left headlight is kind of low (pointed towards the ground) whenever i'm driving at night. Does anyone know how to adjust it so that its raises up a little. My friends said there should be a screw on there or something to adjust it, but the only screws i saw are on the high beam (inner bulb on the headlight). I'm trying to adjust the center bulb to raise it up a little. Help anyone?
Old Aug 17, 2006 | 09:11 PM
fglaustin's Avatar
Default RE: help with my projector headlights
unless this is all different with the lexan lights - the entire unit moves for adjustment. look in front of the headlight and look for a screw at the middle of the top (or bottom) for adjustment
Old Aug 17, 2006 | 09:12 PM
mill$civic's Avatar
theres 2 adjuster ***** or screws or bolts on the back of your headlights, one to move the beam up and down and the other to move it side to side...play around with them and see what controles what, you need to do it at night because the beam moves VERY slowly so its hard to notice it move
Old Aug 19, 2006 | 12:23 PM
lookitzxai's Avatar
oh.....alright then.....there's a "x" shaped screws.....but i wasnt sure if it would adjust its....i thought it was gonna pull the headlight apart or something....i'll give it a try later and see what becomes of it.... thanks
rmiller28
Jun 24, 2011 02:03 PM
red95ex
Nov 19, 2006 05:27 PM
Mario89
Oct 29, 2006 11:20 PM
BoxZes
Aug 10, 2006 02:57 PM
sneekapeek
Jun 17, 2004 04:29 PM
