help please! civic d16y8 sometimes poor aceleration / hesitates
Old Jun 2, 2009 | 04:18 AM
charliccs's Avatar
I research and EJ8 is coupe and my car is sedan. and my car only have one o2 sensor. that`s normal?
Old Jun 2, 2009 | 04:44 AM
The VIN indicates that your Civic is a 1998 4-door EX sedan with a 5-speed manual transmission. The secondary O2 sensor was probably removed with the catalytic converter.
Old Jun 2, 2009 | 04:50 AM
Originally Posted by charliccs
i check the timing with timing gun and only move it less than 1 mm. i put in the middle of the three lines. but i don`t know if I do it good because I research and in some forum they tell that one conector of the ecu i should disconect and do a bridge because the ecu controls the time... I search in the passanger side and I don`t found anything. I only found one conector in the driver side just down in the fuse box a conector of 3 cables.
Click the CEL link in my signature. It will help you locate the service connector. It is located behind the front passenger kick panel. Remove this panel and the 2P connector will be found above the ECU. It branches from the main wire harness.
Old Jun 9, 2009 | 09:42 PM
charliccs's Avatar
thank`s brou.
I search the 2P connector and I found it in the fuse box in the driver side behind the blue conector.
I made a conection between the 2 cables, brown and black and the CEL come on.
I check the timing with the timing gun and I move it just a little bit less than 1 mm and i put in the middle of the 3 lines.
then I check the time without the 2p conection and the time is the same.
I still feel sometimes poor of power and like a misfire.
my car not have second o2 sensor because when I buy the car had catalytic converter and I eliminate the catalytic and don`t have the secondary o2 sensor, I put a test pipe.
what I should do now to fix or check?
thank`s a lot friends....
Old Jun 9, 2009 | 09:45 PM
ej6buddy's Avatar
Can you upload a video of the idle and problem? That usually helps a diagnosis, it's hard to suggest answers to people when they haven't seen the problem firsthand.
Old Jun 29, 2009 | 08:56 AM
charliccs's Avatar
hi friend´s.
the idle is fine.
today I check the resistance of the ignition coil of my 98 civic d16y8. my car only have 71.000 km.
my coil is TEC.
the primary winding resistance in the repair manual say:
0,63 - 0,77 ohm
I check mine with a digital multimeter and the resistance is 0,12.
can this make my car sometime poor or power or hesitaste sometimes??
the secondary winding resistance is good.
should I replace the coil?
what brand are good to buy one?
the accel one 11076 is better than the oem?
thank`s for help... happy day.
iKevin
Apr 7, 2013 07:28 AM
MMG19
Jan 13, 2013 02:53 PM
balquin
Mar 26, 2012 09:49 AM
97_ex
Apr 18, 2007 09:29 PM
hapakolea
Feb 25, 2007 09:34 PM
