HELP! Problems after suspension work
Old Jul 24, 2015 | 02:22 AM
dean_wales's Avatar
Default HELP! Problems after suspension work
Hi guys,
Before anyone says I should have got this done at the garage please bear in mind that I have a young family, we are broke and can barely afford to run the car anyway. So I have to do these things myself as cheaply as possible!
My 2002 1.4 Honda Civic failed the MOT on front tyres, shocks, track rod ends and anti-roll bar drop links. The car has been super reliable apart from the front suspension so I decided to keep her going.
I picked up all the bits at my local parts place and managed to change them all OK over two evenings. I did realise at the end that I had messed up the tracking when tightening the locking nut in the dark as I hadn't used a spanner to stop the track rod itself from turning. But seeing as this needed redoing at the garage anyway I wasn't too bothered as I needed to just limp down to the garage.
The problem is that the car is undriveable due to a really serious knocking sound that clunks with each rotation of the wheel. I think that when I removed the strut I must have let the hub hang forwards and it has disengaged/extended the drive shaft. Some guy mentioned the risk of this happening in a YouTube video but I forgot at the time as there is no mention of this being a problem in the Haynes manual.
There is nothing in the drive shaft section of the manual about how to sort this out. I'm hoping I dont need to take the bloomin hub and everything off :-(
Do you think that is what is wrong? How can I fix it?
We were meant to be going on holiday on Monday!
Please help, thanks,
Dean.
RSB
Jun 2, 2008 05:51 AM
CincyDJ
May 15, 2008 09:38 AM
smurray
Sep 14, 2007 11:11 AM
mill$civic
Mar 31, 2006 01:05 PM
lilol89crx
Jul 29, 2004 06:56 PM
