Help replacing Igniter and Ignition coil
sweet thats what i thought. thank ya much. the only part im worried about is taking the screw off that holds the rotor cuz when i replaced the dist cap and rotor it was in there pretty good, i kinad stripped the screw[:@]
you will have to turn the engine to get the screw on the very top and get into there with a drill and drill the head off and continue drilling to get it down to the shaft to pull the rotor off.
good luck.
good luck.
it would be a lot easier to remove the distrubutor......3 ,12 mm bolts and a couple of connectors
assuming timing is correct , mark the distributor so you reinstall it at the same spot
sledneck82
Dec 5, 2009 09:27 AM
