Need help pls guys>>>igniter code???
Old Nov 29, 2009 | 06:19 PM
sledneck82's Avatar
Default Need help pls guys>>>igniter code???
hey guys, I'm new to this forum..don't really know my way around it yet. I posted another thread but with little result.
The car looses power/bogs/pops only in the morning on my way to work. Sometimes is shuts down...then if u let it sit a minute or two it will start right back up....Mainly around 3000+RPM....after it sits while im at work all day it runs fine the whole way home.
I replaced the cap and rotor....Not solved anything...do i need wires?
I have also recently replaced the ICM and coil.....I took it to be code read...it came up as igniter......Any help guys would be amazing......tryin to avoid the shop.
its a 95 civic si with 280,000kms
Old Nov 29, 2009 | 06:36 PM
http://www.honda-tech.com/showthread.php?t=1901557
pull the codes yourself and let me know
Old Nov 29, 2009 | 09:07 PM
sledneck82's Avatar
Default code
I looked around for the connection to read it like u said....havent found it yet....i'm 99 % sure my mechanic said it was the igniter code..doesnt make sense tho seeing how i just replaced it....I have the old one left that was still working when we took it out..we miss diagnosed the coil and replaced the icm....so i'll give that a try tommorrow hopefully....any help would be awesome! thanks
Old Nov 29, 2009 | 09:42 PM
its right under the glove box are far right side they are there, look real good, i dont trust other peoples words its always best to find out for yourself, that link is how you pull the cel codes, how did your mech do it?
Old Nov 30, 2009 | 04:27 AM
sledneck82's Avatar
Default code
hey again...he used a code reader I beleive..he's a cousin of mine and he gave me the print off...mom threw my pants in the wash,there goes that. I'll look for it tonight, thnaks
Old Nov 30, 2009 | 04:44 AM
well your car is obd1 and doesnt have a ""code reader"" the 96 and up civics do, they are obd2, the only way to pull the codes is the link i gave you......so...
Old Dec 5, 2009 | 09:27 AM
sledneck82's Avatar
Default igniter!
I put the old ICM in and she purrs, no more problems!
Civic4HAF991
Jul 15, 2008 02:33 PM
om4r
May 6, 2007 08:26 AM
DXL
Mar 1, 2007 03:43 PM
noypi
Feb 20, 2007 11:24 PM
skimmy_jimmy
Sep 17, 2006 01:32 AM
