Help with seafoam
Old Mar 3, 2008 | 10:37 AM
inthezone's Avatar
Default Help with seafoam
I know to add 1/3 to crankcase and gas tank. Do I run the other 1/3 through the intake manifold/throttle body? Do I just disconnect the hose that connects from the SRI to the back of the valve cover and use that to suck the seafoam through? I looked at the DIY and the single pic doesn't help. I have a different engine setup so I'm not sure.
Old Mar 3, 2008 | 11:44 AM
inthezone's Avatar
Default RE: Help with seafoam
anyone?
Old Mar 3, 2008 | 12:21 PM
95civic1.6l's Avatar
yes it doesn't really matter which one you put it into. But which ever one you are more comfortable with doing. They do it through both so it shouldn't matter which one you choose
Old Mar 3, 2008 | 08:12 PM
reconstyle's Avatar
I do mine with the FPR vacuum line in this pic it's the copperish colored circular thing thats right about the H in "HONDA" between the valve cover and the air filter.
Just disconnect the piece of hose from that and suck the sea foam in through there.
sedna6
Jan 5, 2020 10:44 AM
Kotadude
Jun 26, 2011 09:04 PM
RellSI
Jun 1, 2008 08:17 PM
RellSI
May 27, 2008 09:49 PM
RellSI
