HELPPPPPPPP!!!!!!!!!!!!!
Old Mar 7, 2006 | 07:42 PM
nwhite82's Avatar
Default HELPPPPPPPP!!!!!!!!!!!!!
ONLY 130 whp!!!!!!!!!!
i have a 88 civic 4dr w/ 99 b16a swap. i have cold air, dc header, feild vtec controller, skunk2 intake manifold, 68mm throttle body, and muff, unorthodox crank, alt. pulley,msd dis6, blaster 2 coil, pro cap dist., high flow cat w/ 2 1/4 exhaust, act extreme clutch and flywheel, aem fuel rail, adj fpr, basically all bolt ons.
what kind of fuel pressure should i be at, and what kind of plugs and wires should i use??
can anyone point me in the right direction????????????
where can i find a manual for field vtec cont.
[IMG]local://upfiles/1161/9642B893099940909A733E8C85B22F54.jpg[/IMG]
Old Mar 7, 2006 | 07:55 PM
sacicons's Avatar
Default RE: HELPPPPPPPP!!!!!!!!!!!!!
I would ditch the controller, unless you are going to get it dyno tuned by a pro. if you dont know what you are doing, those just hurt your power. and how were the AF ratios when you had it dynoed?
Old Mar 7, 2006 | 07:59 PM
nwhite82's Avatar
i dont have a wide band, but guage says running a little rich (NOS), but my fp is around 26???
Old Mar 7, 2006 | 08:02 PM
nwhite82's Avatar
what kind of whp should i be around with these mods?
Old Mar 7, 2006 | 08:41 PM
Kedawei's Avatar
Whp should be around 136 stock. So I dunno what you did. Fp seems low too.
Old Mar 7, 2006 | 09:23 PM
Pete's Avatar
Honestly just go get it tuned by a pro on a dyno. Theyll make power for ya.
Old Mar 7, 2006 | 09:46 PM
sacicons's Avatar
23 is way too low. get rid of the controller, then up the fuel pressure. and get it dynoed with a wideband.
sarah
Feb 9, 2007 08:33 AM
