hids problem...please help
Old Dec 29, 2008 | 02:56 PM
rodgerrogelio's Avatar
Default hids problem...please help
I put on hids in a 2008 civic 4 door Si in the high beam but for some reason when its on the day time running light it blinks and does not turn on and does not stop blinking nether....and its not the hid missed up because I try them and they work...can any one help me out....or show me how to install them??? I really need the help...
Old Dec 29, 2008 | 03:12 PM
daytime running lights run on lower power than regular low beams, and it's not enough for the HID to work. Remove your daytime running light fuse and drive without DRL's. Just remember to turn your low beams on during the day, if the DRL's are a legal issue where you live.
Old Dec 29, 2008 | 03:22 PM
so do i tap into the headlight to connect the hids???
Old Dec 30, 2008 | 06:02 AM
If they use a resistor for DRL, you may be able to bypass the resistor so the HIDs automatically come on full power in the daytime. Unlike halogens you can't dim HIDs down, they are either on or off.
diamondalpine
Mar 27, 2006 01:54 PM
Pete
Mar 15, 2006 09:50 AM
polo708
Nov 28, 2005 08:45 PM
polo708
Nov 28, 2005 12:31 PM
silvabullet
Nov 19, 2004 01:01 PM
