High pitch hissing/whistling noise?
I have a 2007 honda civic. For about the past 2 months everytime I get into my car and take off, it's making this high pitched noise, and it get louder as I accelerate. It's more faint when when I'm in park, but it does seem to idle more. The variation of the sound leads me to believe it's a belt. Is this something I will be able to do myself?
Originally Posted by DrBobGI84
(Post 767814)
According to a Honda bulletin I read a while ago this could be a fuel pump issue. You will need to replace that pump if it is the issue. Google it and I am sure you can find it. I remember they even had a sound embedded in the pdf document to help you diagnose the problem. I have the same problem and I have been driving this car for 2 years without a problem. Not sure of it will break down one day. I have Civic hybrid 2006.
hissing/whistling sounds more liek a vacuum leak to me. If it was a belt, it would be more of a squeal. pop the hood and listen and see if you can tell where its coming from. If its not in the enine compartment at all, i would look into the fuel pump issue that shormanm suggested. If it is comming from the engine, but doesnt sound liek its comming from the belts, my money is on a vac leak. heres a video on how to find a vacuum leak...
How To Find A Vacuum Leak - YouTube btw, if you tend to do a lot of DIY fixes, i would really give his videos a look through, they really help out |
